a month ago
Hi all,
I have a custom connector with 3 selectors used to build up output fields/pills.
The first one (control_type: select) selects a query, the other two (control_type: multiselect) allows selection of fields of the curently selected query and build output pills. All 3 selector have "extends_schema: true".
It works fine.
The problem comes when I select all fields of a complex query and then switch to a simple query: some fields of the complex query remain selected in the second selector even thought they are not part of the simple query. Maybe some caching issue?
Here is a short video: https://drive.google.com/file/d/1ckvYbAv9DSRcOO8DkyCLXApA0v3CqNbg/view
Here is the source code: https://drive.google.com/file/d/1ssbSSxAt4F3DS2dRuUnvll5hAO_VnqML/view
Thanks for any hint, Marek
